Mack's to-do list
kenamond
DSM Wiseman
3,225
68
Feb 15, 2006
Los Alamos, New Mexico
This is for me. Read if you're really really really bored or psychotic or stalking me. It's the stuff I need to or want to do...so I don't forget. I'm lazy, so the list will most likely just grow.
  • Search the forums to find out about wiring in an in-car PDA charger so I can keep it in the car without the Palm battery dying and dumping my OS, apps, etc.
  • Check the FP rewire ground. Unscrew it and dremel off the paint around the screw hole. O2v look fine, but it certainly wouldn't hurt.
  • Change knock sensor for the helluvit. One less thing to worry about.
  • Shampoo that Thai iced tea stain out of the passenger-rear carpet.
  • Reattach the trunk carpet to the subwoofer cover panels, add L-brackets or 1x1 stops to the ends so that the panels are supported at 90° and don't tear the carpet off the masonite.
  • Buy skateboard bearings and do the Symborski shifter plate and cable bushing mods. Why the hell not?
  • Paint front wiper arms. Goddamned desert sand and sun.
  • Get estimate for fixing rear of car. Stop by Don Juan's autobody and tell them I'm not going there for anything ever again.
  • Populate the other pods on the A-pillar. Oil temp and fuel pressure? Oil temp and oil pressure? Least important gets booted when WBO2 finally (if ever) happens.
  • Can I mount my Palm on my sunscreen so that I can flip it down for a log? Wires - including power/recharge - would have to run with the vanity mirror light wiring or equally inconspicuous.
  • Keep thinking about cold air intake options. Fuxin UICP is in the way. Putting the air filter under the frame rail requires rerouting the recirc tube and extending the MAS harness but I don't know if other shit is in the way uner the rail.
  • Install those goddamned BA tweets on the window sails and check the wiring and impedance of the stock dash tweets. Front 6.5" mid-bass drivers may be getting skimped if the dash tweets are lower impedance or wired some strange parallel way. And re-learn what the hell I installed 10 years ago.
