My "Things to Do in 2009" list
crimsondragon
4,300
51
Dec 17, 2006
East Brunswick, New Jersey
Because I keep losing track of shit I need to tidy up in the car I'll just make a list for the spring time or whenever the #### it gets warmer.
1. sunroof - most likely off track, complete disassembly and figure out some way to fix the rust :thumb:
2. thermostat - overcooling :thumb:
3. upper and lower radiator hose - replace :thumb:
<s>4. tranny pan - leaking, most likely from warping after getting it smashed in when the CV joint went</s>
5. replace driver side axle :thumb:
6. hatch struts - won't stay up in cold anymore
7. tire - leaking air...AGAIN :thumb:
8. passenger fender - needs a new one after fender bender
9. corrosion control - underbody rust
10. driver side door - creaks like a bi*** when opening
11. floor mats - need to buy some
12. gauge cluster lights - fix or replace :thumb:
13. brake pads - need new ones at 85k miles :thumb:
14. FP manifold - fix rust, call Swaintech for coating
15. 850cc injectors - RCE for flow test and cleaning
16. engine bay - find out why it smells like gas
17. oil drain hose - kinking :thumb:
18. turbo oil drain - leaking, seal wit massive amounts of RTV :thumb:
19. oil pan - oil drain leaking, also needs AN adapter to be welded on
20. ARP headstuds, retorque to 80 ft*lbs already :thumb:
21. catback - needs neckdown to not neck down, weld in a 3 inch pipe
22. fuel pressure gauge in-cabin - figure out why the bitchin' thing jumps to max pressure when blipping the throttle :thumb:
23. Forge BOV - service piston with new grease :thumb:
24. e-brake - tighten up
25. battery - replace :thumb:
26. keyless entry - replace battery :thumb:
27. reinstall seatbelt :thumb:
28. alignment job
29. get a new bumper or fix current one
30. replace pass side foglight glass
31. back fuel gauge sender out of line :thumb:
32. get new gauge cluster clear cover :thumb:
33. get a new sunroof and rails :thumb:
34. need new PS pressure hose - banjo to flare :thumb:
35. Need new keyless entry cover :thumb:
36. still leaking oil
37. boost leak test
38. fix exhaust leaks
39. fix water leak
Most likely with steel wool, elbow grease, and then either black rustoleum paint or rubber underbody spray.
Long list but it seems like there are a few easy task you can knock out pretty quickly LOL.
Have you ever thought about using some sort of media-blasting under the car? It would save you SO much time and hassle. That list is mighty long. Good thing you have all of spring and summer when it gets here. I just spent about 5 days doing a cylinder head swap only to find other leaks that didnt show when I had the car running on the jack-stands for over an hour. Oh well. Good luck to you man....
No I didn't because I don't have a media blaster. Elbow grease will have to suffice. Adding an alignment job to the list. I just smashed the front passenger wheel into a curb.
