1G Machinegun Backfiring
Nightfall Talon
Aug 3, 2019
Lubbock, Texas
What I have - 1992 6-bolt TSi 5-speed AWD Talon, mostly stocker. Engine is freshly built from the ground up, driven around the block twice. EGR removed, vacuum hose clean up done.
Problem - Under load (in gear driving), repetitive rapid backfiring, feels like lack of power.
What I've tested so far - Checked plugs, boost leak test. (Came up in the search as the most common issues)
What do you guys think?
Try it with the mass air sensor unplugged without making a bunch of boost, it sounds like a fuel delivery issue, as in it sounds like its lean.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
