Car backfiring
Pat026
136
Nov 27, 2016
Milford, Pennsylvania
Ok so i was on here once before, trying to figure out things. I own a 92 tsi, and experiencing alot of problems. So my car has a strange idle, valve ticking,and lots of backfiring. I was told the ecu needed dsmlink, because the ecu wasnt a turbo ecu. Im buying dsmlink very soon for the record. However my buddy brought over a spare turbo ecu and, we plugged it in and fired her up and still the same issues. My mods are a 16g, 255 walboro fuel pump, a safc2, syock 450ccs. Now i zeroed out the safc today and left the rest of the stuff alone car runs steady on idle but sounds poor and now on initital start up i heard a really loud bang from the engine like a backfire but worse i immediatly turned it off and checked everything, seems to be fine my wideband,isnt giving,me accurate readings i read a 7.4 but it flashes sometimes just dont know how to solve this. Any ideas
Sounds like a BLT (boost leak test) is in order for you...
Also if you are running that rich at idle, you may be experiencing FPR (fuel pressure regulator) over run. Typically it is advised to get an afpr (adjustable fuel pressure regulator) with the wally 255.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
