Machined GM MAF sensor
bme91gsx
88
Mar 16, 2008
Muskegon, Michigan
Hey Guys.. Lately Ive been machining GM maf sensors to help eliminate boost leaks at this point in the intercooler system.
Basically what I have done is machine the "notch" out of the sensor and gave the clamping area more width and depth. This provides a better sealing surface and clamping area to prevent leaks.
That's usually where I blow a coupler off. The coupler had to be notched to fit properly, so the t-bolt clamp doesn't get to put force on it correctly and eventually it blows off. I plan to eliminate it all together with a MAP though.
