LPH fuel pump for 1250cc?
You buy a fuel pump based on your needs. What are your plans for the car? Do you have supporting mods for larger injectors and fuel pump?
My guess is a Walbro 255 would satisfy your needs.
A 255 is not enough to support 1250cc injectors. You'll max out the pump before you max the injectors.
Fuel line size depends on what fuel you want to run. But stock lines are good for quite a bit of power, on gasoline or E85.
You'd need something more like a walbro 450 LPH than a 255 to fully support 1250cc injectors. Since the factory fuel line is very close to a -6 AN, eliminating the banjo bolt on the fuel filter outlet and replacing it with a -6 AN fitting (filter to rail kit) will likely be an adequate modification to the fuel line upstream of the rail. On the return end you'll want to install an AFPR.
I would never ever buy a big walbro single for those fuel demands. I run 2 x255 externals and stock lines with similar size injectors, and could use just a bit more pump.
Yeah that's another way to do it. He asked what he needed to support those injectors and based on the numbers I just gave the simplest answer.
The only reason I say that is because, I feel like our electrical pass thru is garbage, and I don't feel like there is a good way to do it.
