Lower heat shield , with or without????
lookinfor400hp
102
Sep 28, 2005
Jacksonville, Florida
I have searched and found nothing , so here we go.
I recently installed my EVO III 16G , and an external dump O2 housing.
My question is now obviously the lower heat shield will not fit , do I need to fab one up or run without it.Does anyone have any experiance , or could give me a heads up on possible failure of or melting of the fans , or alternator failure from the heat , any premature hose failure , things of that nature due to not using the heat shield?
your fan will melt..... mine did.....
as far as the other items mentioned, I have had no issues with hose or alternator failure.
Will it not fit because of the different turbine housing, or is the O2 dump in the way? If it's the O2 dump, I would just try to cut it to fit.
I don't have one nor do either of my fathers cars - no problems here. Now, if I had one I'd probably put it back on, but all that we have purchased have come without them.
Correct , it will not fit aroung the W/G dump tube portion , I think I will fab up one anyhow and save the stock one just in case.I am not so much worried about the fan , I really dont want to keep changing alternators , its allready a 13 year old car , and there are electrical connectors and such right there , those I think are my main concern.
