lower end rebuild?
baby huie
102
Aug 22, 2004
pueblo, Colorado
hi i am doing the lower end on my 95 talon tsi turbo awd ive herd that you cant just un bolt the oil pan and put new bearings in is this the truth or did i read it wrong. please hit me up if u know the answer is it like changing bearings on a honda or is ot not possible that way.
to put new bearing in, u have to remove the crank, wipe out all the dirt, and torque the main caps back down. Might as well pollish the crank white its out, and possibly do a full rebuild. Make sure u use lots of engine lube on the TOP side of the bearings so the surface wont scratch up. Go ahead and fix all the small things that may need to be fixed also. If u are short on cash, slowboy racing has a interest free 90 day same as cash. May be a good idea for you. Hope this helped. Shawn
i change the bearing on mine by just dropping the pan. i had a bad knock, and not enough to rebuild it. if i pulled it out i would be putting a 2.4 back in.
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
