low idle when in gear 92 talon awd tsi a/t
SmashingDsm
71
Jun 12, 2010
palmdale, California
hey guys , i have a 92 eagle talon 16g turbo, front-mount, 255iph fuel pump . my issue is car idles fine when in park like around 1200 -1000 .when i put it in gear ,reverse it idles low give it gas and it will die or close too dying. idles around 500, i have checked for leaks boost and vacuum .what could it be? i would appreciate the help . been struggling for month.:( thanks .
what your describing i had the same problem. mine was the coil packs id check those i was sparking but blue and orange and on cylinder 1 i was barley getting spark i replaced them and solved my problem. id pull the plug wires wile the car is running and see how your sparking and if there is a difference between any of them you found your problem but be careful its not fun getting shocked, id also check your mass airflow sensor (mas) or idle air controle (iac) :thumb: good luck
yea i checked all leaks isc working fine fiav good coils are good i was wondering would the lines on the transmission running to the radiator could be switched around .if so is that a big issue or doesn't matter how the go? and also to make sure the lines going in to the fiav are correct does anyone know where they go?
