TasosEclipse
- 118
- 4
- Oct 20, 2016
Thiva,
Europe
Can someone tell me
How i can make my low beam stay on with my high beam ? Thank you
Same for both of my 2G'sI thought the 2g Eclipse was already wired the way you're asking about. In my car, if I turn the high beams on, the low beams stay on. I'm almost positive that nobody has messed with the wiring because I've taken the car apart multiple time and the only wiring that doesn't look stock is the stuff I've done.
Sorry - I thought that's what you wanted - for them to come on together (since the low beam already stays on with the high beam).Sorry but if I connect in the passing switch when I turn on the low beam the high beam stays on too
That is how it's designed at the factory. If it doesn't work that way, it's either broke or someone re-wired it. Do your low beams normally work on low beam?I want when the high beam is on the low beam stays on
Ah yes, I didn't notice. Ya, that's got to be it. They probably have daytime running lights (and whatever else) so the wiring is completely different (and I don't have the diagrams). Maybe someone else can help.He’s in Europe. Could it be a euro thing?
My cars US spec so not much help. I might be very wronv with this as its been a while since i used the lights on the car but i used to get 1 or the other. It used to click over so if i held the stork it would have both working. Click it and the low beams cut off and im on high beam only. My wiring for the headlights has not been altered. Only side light wiring has been added from the oem amber corners.@ec17pse Bobby, are your headlights and high beams this way?
Maybe check part numbers for headlight stalk US vs Eruo
