2G LOUD tick after changing seals
Gysgt Guy
603
4
Mar 6, 2011
Lubbock, Texas
Had bad smoke after car was sitting for years. Through y'alls amazing help diagnosed valve stem seals were the culprit and that is cured. Now I'm having an extremely loud tick. I have attached a video...it seems to only be happening above 1300rpm..no occurrence at idle which makes me think it's not a lifter tick?
I'm as sure as I can be without ripping it back apart and replacement them again! Haha
And I did not remove them, that clip is after running for about 1/2 hour burning off all the smoke, and while motor was warm
You have to remove the valve cover.
It could be as simple as a rocker falling off of a lifter which you would see right away.
It could also be a loose bolt on the cam cap causing the cam retainer to rattle against the cam.
The valve cover is a 5 minute job, don't get discouraged yet its probably still something minor
Just pull the valve cover and post a picture... Its like 10 minute job, tops. If you can't pull a valve cover on a DSM, its time to send it on down the road.
