W_Static
- 0
- Nov 25, 2004
San Jose,
California
ok, my problem is after 2500rpm theres this noise, its hard to explain. it sounds like a dirt bike, but under my hood. the noise is almost nonexistent while idling or under 2500rpm but after that you hear it, and its really noticable after 3000rpm. i thought it might be a loose valve or rod but i checked'em out and theres no play. i also checked the turbo and theres a little shaft play which is common on cars with over 100k im still getting boost, and the cars will get to 6000rpm but at that high rpm its unbearable. my fluids are fine, oil change 40 miles ago, but the noise happened 15 miles ago. anyone know what the problem might be??
