Nasty Dream
- 455
- 3
- Aug 30, 2011
Alexandria,
Virginia
[ame]http://youtu.be/Kl2VObChR8s[/ame]
This is not my car, but mine sounds exactly like this, for about half the time. The tapping cuts in and out on mine, and sounds like it's from the intake manifold area.
Eclipse GST 1995 [DSM 2g] KNOCK SOUND. SPUN BEARING? ROD? VALVES?
What do you think that knocking sound is?
I need someone that knows for sure exactly what this is. The comment on a similar video suggest balance shaft bearing.
The engine is currently running smooth, but it was shaking REALLY BAD front to back until I got the fuel pressure regulator fixed and I put fuel injection/combustion cleaner/water remover. Do you think the balance shaft slipped?
I don't totally know what I'm talking about, I learn as I go. I've had this car a long time.
2nd owner. Bought stock in 1999-2001 timeframe with 51k.
16psi boost, 120,000 miles, original engine and turbo. Head gasket at 50,000 miles by dealership.
Well maintained and relatively babied.
Obviously, I'm VERY UPSET, but I have other transportation and you know: racecar.
I believe a garage was driving my car hard when it was cold.
There was way high fuel pressure at the time, and the fuel pressure regulator failed under the garage's care, but the engine damage is probably unrelated. (that's fixed now, with AFPR and gauge)
I need to know:
What's the problem
What kind of labor will I have to do?
Can I fix it while the engine is in the car?
Can I fix it with jackstands?
Do I need an engine hoist?
what to buy, i.e.: balance shaft elimination kit, OEM rod, larger pistons, camshafts, springs, lifters, etc.?
I already have all the parts to redo the timing belt, cooling system and everything else.
I am ready to order the parts immediately. What parts should I buy?
Any part that comes off the car, I want to make it better if it will help me get 350-450HP on 93 octane on a street turbo. But I don't want to replace anything needlessly. So stock OEM parts will suffice.
Again, I want 93 octane (with 10% ethanol) compatible on a street turbo, so we are looking at 16-18 psi maximum, and I want 300-450 HP.
I also need help deciding who to take the car to to rebuild the engine, if you guys don't think it's do-able.
I'm in Northern Virginia. This happened while under the care of the shop that put in my clutch. I am pretty handy and have most tools, but don't have a lot of experience.
THANK YOU SO MUCH
I need to know:
What's the problem
THANK YOU SO MUCH
