Balance Shaft Bearing Question
zack13277
69
Feb 11, 2012
Plymouth, Wisconsin
I had an idea and was wondering if anyone else had tried this. I am doing a balance shaft elimination and was going to turn the balance shaft bearings 180 degrees and port the oil filter housing, but I was wondering if anyone ever tried to just drill a small hole in the bearings, smaller than the stock sized ones, because that would lower the oil pressure, but would it make it too low? Let me know what you think of it. I was just curious.:hmm:
Yep thats what I do to every motor I've built. It doesnt harm a thing. rotating the bearing 180 degrees has the same effect and putting a full bearing in.
and NO dont drill any holes in the bearing. that oil passage needs to be blocked or your oil pressure will plummet due to shooting all of he pressure through the gaping hole.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
