lots of oil in uicp
joey17
152
Sep 27, 2008
hartford, Wisconsin
so heres the problem i have a bad boost leak but thats in my other thread. i pulled off my bov and there is a good amount of oil just chilln in my uicp i new i had blow by but wow this is way to much and i check my turbo all the time no shaft play. what els should i check/do
Why everyone jumps straight to pistons and blown turbos?!!! You see this tiny hose that goes from valve cover to air intake? See oil in it?
Put an inline filter in it and you'll see it'll get soaked in oil after 600 miles. That's the most likely cause.
There's lots of people sporting breathers on DSM's, but it's not the correct way to vent the crankcase. It will contaminate your oil with blowby pollutants faster having it plumbed that way (what the PCV system is designed to prevent), not to mention you are introducing unmetered air into your intake. To do it right, you need to stick one of these suckers in between the PCV valve and the intake:
Check Valves - US Plastic Corporation
This guarantees that your PCV valve will never blow pressurized air into your crankcase. Then make sure you have your other hose going from the the left side of your valve cover into your intake pipe. If you're getting that much oil in your lines, you can stick a sealed catch can in between valve cover and intake pipe. Personally, I've never bothered installing one though.
That check valve prevents boost from going into your crankcase from a leaky PCV valve. It is getting harder and harder to find PCV valves that don't leak from the get-go... I've even had OEM Mitsu PCV valves leak fresh out of the box.
