Losing lots of oil
dsm4bk
68
Nov 25, 2002
My 95 CW'd, so I got a '97 engine swapped in, and the guy who did the swap for me eliminated the balance shafts. He left one shaft in, and put the stub shaft in the other.
I got the car back from him in December, and now 3 months later there is a really big oil leak (leak could have always been there and got worse over time) I got people to look at it and they cannot see where it is coming from, because they said its coming from behind the front cover (they'd need to take all the belts, covers off to see) They say it is most likely and oil seal, or if the guy tightened the front cover too hard, it could have cracked, or a screw from a tensioner might have come out. So I told the guy who did the swap for me to check it out to see if he finds something that he did wrong, and he doesn't want anything to do with it (hes done work for me in the past, so I trusted him) but I paid good cash for the whole swap.
How likely would you say that it is his error that I'm getting a bad oil leak after only 3 months????? the car is close to stock, so don't say anything can happen blah blah blah.
Everytime I drive somewhere, I can pull the car back a few feet and see a few oil puddles from under the timing area, so when I drive, it must really piss out of there.
Please help.
yeah I took the top timing belt cover off, and the belts completely clean (not spraying oil like if the bottom got oil on it)
I would say it definately could be that guys fault. If he didn't get every last bit of gasket off from the front cover, oil filter bracket, etc... When the bolts get torqued down, it could crack, causing a significant oil leak. I suppose if he didn't replace the front crank seal, that could do it too.
It is really hard to say with out taking the lower timing cover off.
these are the parts that I had to get him when he did the swap:
MD098626 oil pump stub shaft
MD187905 front cover gasket
MD069949 crank oil seal
MD069950 balance shaft seal
MD095355 oil pump seal
MD041021 front cover O-ring
MD185528 oil filter bracket gasket
MD620908 oil filter bracket O-ring
