looking for turbo kit without changing stock ECU
atblacktalon92
186
Nov 26, 2002
winnipeg,
HI, what kind of turbo kit is suitable for running low boost in my 4g63 engine without changine my ECU?...let me know sum stores that sells them...thnx later all.
sigh....SEARCH?? prostreetonline.com is the only company i know of that sells a turbo kit for our car and at a rather fair price...2500 bucks is cheap for all u get, check it out. i may be buying one for my car as they run 6-7 psi b/c i dont have my internals upgraded, yet.
You can use the stock turbo system on it and maintain the NT ecu as long as you can find a set of high flowing, high impedence fuel injectors to swap in and upgrade the fuel pump and install an AFPR.
However, please do not do this. Using the NT ecu is not a good idea. the turbo ecu already has the proper fuel maps programmed into it as well as the added benefit of a Knock Sensor, something the NT ecu does not support and something you'd be foolish to run without.
As far as a store that sells the kit....um the dealer. Just go junkyard and eBay hunting. I did mine for $800 and that included doing it PROPERLY(using the turbo ecu).
