General looking for free 1G logging software
92awdgsx
487
17
Sep 16, 2002
Lincoln, Nebraska
does anyone know where i can get free logging software?
For some reason the 1.5 version of mmcd no longer has the ecu reader test on it (if it does I cant find it). I went back to using the 1.3d version which has the ecu code reader on it.
Thought it was just me that couldn't get the ECU trouble codes on MMCD. If someone can tell where they are on the latest version, would be great :)
2.4 turbo Hyped said:
They arent on the 1.5 version. They are on 1.3d though. Email me and I can send you the 1.3 version.
Huh? I have 1.5 and can read codes. ECU codes are with the actuator test and injector screen as 'Test' under the Mode menu. Tap MMCd in the upper left while looking at the saved logs list to get to the menu. They were moved there in 1.4.
I have a palm v and the 3.1 os on it. I went to the palm website and it says there isn't an upgrade for the OS. is there a way I can put on 3.5 so it can run this software of is there another option for those running the 3.1 version of the palm os?
