looking for a camber kit
miniturbo23
408
4
Aug 14, 2008
A-town, Arizona
my front of my tires are getting eaten up from the very edge end, my tires are new but still I gotta get this fixed been looking aroung and see all kinds of camber kits but dont know which to choose. any advice on some you used before? which is best? :confused:
If it's the very edge of your tires I suspect what you really need is an alignment as your toe is probably out of whack.
Exactly, its usually bad toe thats the cause of excessive tire wear. An alignment will probably help. If you still want to get an adjustable camber kit for the front, look at the Ingalls or SPC control arm anchor bolts or just adjustable bushings, which should do the trick for most. Bushings alone can add up to .75 deg to your camber which should be fine for most setups dropped less then 2" as its actually ideal to have -1.25 to -1.5 camber in the front to help with understeer, since these cars tend to understeer from factory alignment specs
Get toe set to zero all around.
