Camber kit
Righteousrioboy
Sep 17, 2016
Cornell, Wisconsin
Hi my name is Jason and I purchased a 1gb talon and have done minor stuff too it suspension wise anyways LOL....my problem is I have positive camber on the front wheels I bought a wedge style camber kit and can't figure out this is going to fix my problem? Pls help tia
That right front tires tipped out it looks like? Idk now the way it's sitting on the St everything looks like it's kicked to the right
The tires are tipped out on top their not underneath the car fenders like their supposed to be
They look angled at a distance but up close they look straight? Idk guys LOL ik I still need to replace my outer tie rod ends
And just where is that kit supposed to install?
LOL between the upper part of the spindle and the strut. This is y I'm lost? If I put these in its gonna do exactly the opposite of wat I want I'm sure of it n they can't go from the bottom up
No not yet waiting to order tires first I have 16s I could throw on ig. If I don't have camber y are the wheels out only in frontnot the back to? And it's scary with handling LOL
Their bald almost just wanted to try them out n set the suspension for them n no matter wat I do with the dampening it won't handle better. The pic of the tire I don't believe the ring was there when I bought them
I have installed a meagan racing coil over suspension setup with a front strut tower bar and new oem control arms with ball joints. I'm unsure if I'm the same height or not
If you don't go too low you most likely don't need front camber kits but the rear you most likely will but you can't know for sure till u go get an alignment
So I figured out my camber issue!! TX for the help! I just had too loosen the bolts and push the top of the spindles in!! Now for tiexample rod ends tires and an alignment
You just found a symptom. Those bolts should have no slop. You have the wrong bolts. There are eccentric bolts available. You need to look again.
Hmm.....
where would said bolts be located? Because I only have the 2 at the top of the spindle. And I figured those were it because they both move or are loose in there until tightening obviously LOL
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
