Looking for a base map
tcavenger99
109
May 24, 2008
mount pearl,
OK installed mega squirt (megasquirtnspark v021s ) i am using it to control only my fuel injectors right now using someone Else's tune because thats what the guy that had it before me had done . the problem i have is my laptop crashes and i cant get the fuel injectors to fire i am buying a new laptop next week yet i would love it if someone had a tune that i could load in the meantime . i am running 15 psi of boost on 36 lb injectors with a jaw wide ban using all gm sensors .
attached is the tune i am using
ok to do that i flash the ms and reprogram it right plus what would would be the better to use on my setup
ok flashed the megasquirt with new firmwere it erased and then compleated yet (029y3 or 029y4.) now my com wont connect it says firmwere doesent match and when i read siginuter it says siginuter is a bunch of jumbled letters dosnt make sense i am using diy tunning some help please.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
