420A Base Fuel pressure
Eclipseturbo4
73
Jan 12, 2007
Cedar Rapids, Iowa
Hey I have a 96 esi i.m putting on an adjustable regulator on and I wanna know what the stock fuel pressure is so I can get it all dialed in...
The base fuel pressure for all 2g dsm's (4G63 and 420A) is 43.5 psi. This is measured with the vacuum line removed and plugged.
There you go Nate :p
After you set the pressure, hook the vacuum line back up and it should drop down, don't worry, it's normal as it's adjusting for vacuum.
  • Wanted 6 bolt NT water pipe
    • chrisman287
