Looking at buying a turbo...
interex
1,039
Apr 28, 2008
Centralia, Illinois
I'll be the first to admit I know nothing about turbochargers. I have been looking at different builds, and setups and looking at turbos here and there. I came across a brand new Garrett turbo that says A/R .65 .89 M-24 on it but I'm not too sure of what that means, or if it's a good size. How much horse power would this be good for? Would it work for my 2.3L stroker build?
Because a 500hp dsm is a beast. You start losing traction in an AWD at that point, and drivetrain issues become prevalent. I am there, and trust me, it's not that fun ironing out the kinks in your system. My trans is currently at shep's. :(
Well that's fine. I'm building my engine off a few other engines listed in the dyno sheets and I feel that it will save me time, and money to just do what I can to build a roughly 620hp engine than worry about a 400, or 500 hp engine and then try building up from there. Like I said after all my parts are bought and everything is assembled all I will need to do is tune.
I looked at IPT about a Performance Rebuild kit for my Automatic AWD. They have a kit for $429 and they want more than that for a high performance valve body. I think I can just do the valve body modifications myself and save me some money. I just might buy their kit and have a local transmission shop rebuild it for me. I live in a really big drag racing community and engine/transmission shops are around every corner. :(
Found this in an online ad... Is this a generic turbo or what??
P-Trim BIG T04E
This is a brand new turbo. This turbo is rated at 650 HP. This turbo is for someone that wants to have a really fast car. The compressor wheel that this turbo has is a GT40, the same compressor wheel that the new GT35R has. This turbo has the latest bolt down 360 degree thrust bearing design. This essential design ensures a long life, even under the most brutal racing conditions!!
Turbine specs:
-T3 round 6 bolt outlet turbine housing .83 A/R
-76 trim T350 turbine wheel (stage 5)
Compressor Specs:
-T04E housing 2.5" inlet 2.5" outlet
-56 trim GT40 compressor wheel 2.41/3.22 (61mm inducer)
-Flow 65lb/min
-Divided Turbo Flange
Uh, anything in a TO4E comp housing isn't going to be pushing that much air LOL
Alright. As I said before I know nothing about turbos. I honestly have no idea what the turbine and housing numbers mean. I'm trying to learn, and keep on searching :)
This guy say's this is a "SBR" 60 trim. What can you tell me about it?
or anything about this turbo below...
I still dont understand what the ".50" ".60" and ".70" mean, I don't know how to tell what is good, or bad. Or what is good for 600hp
I would need the Part number to give you the exact application and model number!
It looks like it is a GT40 style turbo off of an 8.0 Liter International!
It could work but as stated before it will be laggy!
also a the wastegate will be set at anywhere from 22 Psi - 26 Psi!!
just my $.02
Turbo
I read that page already. Does not mean I "understand" exactly how to meausre what the sizes mean, what is good and what is bad.
Big A/R's mean slower boost response and spool, but more high end power due to less back pressure.
Small A/R's mean a faster spool and boost response, but less power due to more back pressure. They also have a tendency to surge from such a quick spool. Surge is when the turbo is putting out more air then what your engine is taking in.
With a stroker engine, you can afford to go with a larger A/R on a mid frame turbo because the increased displacement will still spool the larger A/R. Or you can go with a larger turbo with a medium A/R. Or, if you plan to rev it pretty high, you can go with a big turbo and big A/R and it will act like a large turbo on a 2.0 engine. See what I'm getting at?
Sort-of. My rev-limit is going to be between 8000 and 8500 RPM. I would like a turbo good for 600+ HP between 3800 and 8500 RPM. My head is a SBR Stage VI, Manley valve train, and Crower 280 cams with a 90mm throttle body.
I found a garrett turbo, it say's it is this...
.50 AR COMPRESSOR
.70 AR TURBINE
COMPRESSOR WHEEL .57
He doesn't list which Garrett it is other than T3/T4. Says it is good for 650hp. Good, or not?
