dsmcantwait
- 0
- Jan 20, 2006
Phoenix,
Arizona
I was wondering how or where you go to have a compression test done? same quetion for a leak down test, and the ignition timing? Please help me so I know how to test the major parts of the car
dealer to get it inspected completely. If you want to do a compression check yourself, you take all the plugs out at once. Then unplug the coil pack so you dont get killed, and unplug the "Engine" fuse in the fuse box, this disables the fuel injectors. Then plug the compression checker into the 1st cylinder, and crank the engine a few times while holding at full throttle, and watch the compressoin gauge go up, once it reaches it's full measurement, you can stop cranking. Remember that as you progress thru all 4 cylinders, the battery will become slightly weaker, and this can throw the numbers off slightly.
