Looking 4 hx35 1050cc injec 255hp pump 25psi tune
SirB00stAl0t
Aug 21, 2010
easley, South Carolina
im not near a awd dyno and i need a temp tune for my car anyone have one they can send me? for ecmlink? would be a killer thing to help a fellow dsmer out
I don't think that is a wise thing to do. Every car is different and there fore every Tune will be different.
EcmTuning, when they sent you your Eprom, there was a stock map for timing and fuel. You can use that relativity safely even with a HX35.
Now you do have to tell ECMTuning the size of injectors you are running and if you have changed your Base fuel pressure. There is a nice video on how to do that now at ECMTuning's website. Here is the link. It is called ECU - Initial setup.
I have watched all of those videos several times, and usually watch them every time I setup another car.
Good Luck!
There is no such thing as a "temp tune" for ECMlink. Every car is going to be different. This is not like using a standalone tuning system (AEM, for example) where you need a base tune just to get the car started.
As enos mentioned, you're still utilizing the stock airflow, timing, and fuel maps, so you'll be safe. If you want help with your tuning, do some reading on the ECMTuning wiki or watch their tutorial videos. Or take logs and post them on here or the link forums (which you should have access to) and people will do their best to help you.
