Logger reading 2G
VtecvrsTurbo
654
8
Oct 25, 2005
Massachusetts
I was going to get a logger but im not sure now. I know that my 2g doesnt show knock counts on the logger, so how will I know whats wrong? I also know it shows o2 voltage and timing, but what about those things will tell me whats wrong with her?:coy:
The only way you'll see knock count is with a stand alone or dsmlink. With a logger you can see where your timing curve dips and that is more than likely knock. I'm using a logger and a safc combo. I dynoed my car last weekend. I got 297whp.
I only want it to see whats wrong. I have nothing to adjust. My car bogs STILL and ive done every test I know. compression, boost leak, plugs, coil, fuel filter, any ideas?
Your best bet is to try and find someone in your area that has a logger. I'm sure there are guys on this board in your area that would be more than happy to help out.
Can you explain more about your problem? Does it happen at WOT or idle? What brand and gap of plug are you using? Do you have a CEL? Etc.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
