Erratic MAS reading with Innovate logger
sqr
82
Apr 3, 2009
Lancaster, Pennsylvania
I have a one g mas on a Starion. I am seeing erractic hz readings on my innovate motorsports logger. I am new to logging and am not sure what is normal. The injector duty cycle does track the bigger and wider hz swings. It is a little hard to see that as the duty cycle lags a fraction of a second behind the hz changes.
I am seeing as much as 2200 hz but the problem starts much sooner. I can feel some surging from the car as well. How does a mas act when it maxes out.
I tried a stock Starion mas and it was even worse
Frist g Mas
Starion mas
I switched to a 2g maf. The really big oscillations are gone and the car runs much better. Clearly i am flowing more air than the 1g could meter.
That said i am still seeing 300-400 hz swings in the logs. Dose the signal really fluctuate that much?
2g maf
You can view my logs here, if you have Logworks 3 on your computer.
Erratic mas reading on Eclipse mas - Page 2 - Innovate Motorsports Forum
Thanks, John
