Simonsaysr1
- 135
- 11
- Jan 30, 2016
Rocky mount,
North Carolina
So my Transmission wouldn't let me shift. I know this sounds stupid. But the staked nut came loose under the end cap. It has alot of free play and I feel as if it's causing the clutch disk to not fully release due to the splined input shaft to sag and I feel it's causing the edges if the clutch disk to drag on the pressure plate and flywheel. I've changed the clutch to an act2100,i had the flywheel stepped, I got oem master and slave cylinders, I vacuum bleed it several times with and without a Russel quick speed bleeder
