turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
I want to make a post where we can share fuel/spark maps to see what each other are doing and how it is treating us.
I have a 1g 6 bolt, stock cams, rod and just a set of 8:1 pistons (stock bore) and the rest of the mods are in the profile. I can't host a map just yet since XP doesn't recognize my win98 floppies,
but the short of it in the timing area is 40* at 30h/g's - ~24 at zero vac and boost, then at 4k i start with 16* of timing and gradually raise it to20* by 6k RPM with AFR's that are in the 11.5 range from 3000 to 5500 rpm, then raises to 10.5 by 6k RPM and up on 91 pump gas, no alky (YET). It's NOT my ideal AFR's at WOT yet either. I want it to be,where I'm shooting for. That's 11.2:1 across the board..this is also tuned at 8 and 18 PSI and only 20 minutes to tune the WOT areas.
Let me know what map you're most interested in
My latest "cold weather map" for a the above mentioned motor with 720cc injectors and the map has adjustments for hot weather
Or, my base map for 550cc injectors
Both are at 44 PSI base fuel pressure
let me know and ill host the map and software download link... you do teh same and lets learn!! Try and give similar details when posting your maps, or just say if it's ALL in your profile.
