- Thread starter
- #26
Chumpaumpalumpa
- 1,554
- 303
- Jun 16, 2014
La Habra,
California
If that leak down test shows bubbles in the coolant, then I am almost positive that you already have your answer. Your log looks almost identical to what mine did when I had the same issue. If you are not losing coolant in the overflow yet, it could just be because the leak is currently so small. Also you may be losing your coolant by burning it. Just in a very small amount.
Even some people that do the head gasket 100% by the book have issues getting MLS gaskets to seal.
So I went to go start it rn and nothing from the injectors. They have power but aren't getting yanked to ground. After cranking and screwing around suddenly injectors 1&2 decided to start firing. First number 3 didn't want to fire and now this.
Also as I've been typing this up I've been cranking and turning it off and back on and injector 4 just decided to join the party. WTF
that's why it's so off. Charging system is fine. Under wot that isn't accurate through the ecu. 13.8 is the lowest it actually drops to.
