a1320eclipse
- 176
- 1
- Mar 26, 2003
Spokane,
Washington
Ok the basics, 90 tsi awd. Mods: K&N, Turbo xs HPmbc set at 15psi, 3" cat back with gutted cat, walbro 255. according to the A/F gauge it was leaning out at around 4k to redline in every gear at 15 psi and at 11 psi it was leaning out at around 6k. It does have a boost leak at the throttle body and thats it, when i charge the charge pipes it doesnt hold even 3-4 pounds, it bleeds it all off pretty quick. but anyways, i was able to get a logger goin and im still learning about all this but all of the sudden at around 45 it starts with a knock count of 7 and by 5500 its at 43. and the injectors are at 93%. the O2v is 0.09 and timing advance is at 17 degrees. also when the car is idling its got a tps % of 10.1, shouldnt that be at 0? any help would be appreciated.
