Stapl3
DSM Wiseman
- 2,293
- 1,014
- Oct 27, 2004
MI,
Michigan
I originally posted this on the link forum, hoping someone here can have some ideas.
My openloopmaxoct table is untouched. I realize I should eventually change my target to the low 11's (93oct) in the appropriate cells. My wideband is pretty steady, so I averaged it out through the pull and it's a full point leaner than the target. To make the afratioest and wideband line up I should change my global, right? I saw this in a thread on the link forums:
That example changes the global from -40 to -45.5, which seems like a lot of change to me. That formula makes my global go from 64.1 to 60, meaning my 1250s are actually 1125s. Plausible? Fuel pressure is at 37psi, I used a few gauges that all gave different numbers so I said the hell with it and used a linear sensor through 'link to set base. No boost leaks, all sensors are calibrated correctly.
93 octane
BM 1250s
FIC easytune
340 intank, rewired
Buschur bolt on afpr
399 MAF
60-1
8.3:1
272s
AW IC
Cyclone Manifold locked to favor lower RPM.
I know the car needs more boost. Currently on the stock 1g bov so I don't want to go higher just yet. Plan to gusmahon mod it in the next couple days.
3rd_1: I changed my global to -60.2. The car feels better overall, but Afratioest and wideband are still not lining up as I hoped at WOT. Any ideas?
If you have an A/F ratio target of, say, 11:1 and a measured average WB value of, say, 10:1, then you just need to lean the mixture out by multiplying global fuel scale by 10 / 11.
If your global fuel adjustment is currently -40%, then your actual global fuel scale is 0.6:
1 - 0.4 = 0.6
Multiply 0.6 * 10 /11 = 0.545
That's the new global fuel scale (multiplier). It's less than the original 0.6 factor, which is going to result in a smaller pulsewidth and less fuel which means a leaner mixture.
A fuel scale of 0.545 corresponds to a global fuel adjustment in ECMLink of:
0.545 - 1 = -0.455 or -45.5%
93 octane
BM 1250s
FIC easytune
340 intank, rewired
399 MAF
60-1
8.3:1
272s
AW IC
Figuring out what my injectors actually flow has been a headache.
