Lc1 ecmlink logging
onefast2gdsm
866
6
Aug 30, 2010
millersburg, Pennsylvania
I just Installed my innovate lc1 wideband last night and cant get it to log correctly in link. I followed snowboarders tech article for a 2g install with narrowband simation and logging in link. I reprogrammed the gauges analog output and chose lc1 in link. The afr is a couple of points off. I then chose linear wideband and put the numbers from programming the gauge in, and its still not right. Also, when in a log, my front o2 voltage doesnt change in the displayed values section it stays at .20, but looking at the map on the log you can see the signal bouncing up and down.
