- Thread starter
- #401
DSMunknown
- 4,108
- 43
- Sep 16, 2004
Worcester,
Massachusetts
Now it's my thread.
At least now the title suits the topic.
At least now the title suits the topic.Follow along with the video below to see how to install our site as a web app on your home screen.
At least now the title suits the topic.I HIGHLY recommend jacking the car up, dropping the downpipe, and taking the starter out to reach the four hard-to-reach bolts at the bottom of the manifold/head. I replaced my starter back last fall, and knew ahead of time it was a cinch. But I had somewhat forgotten how much room there was behind the block with the DP and starter out of the way. There is TONS of room for your greasy little hands when removing these two things. This especially goes for those of us who are under 5'6" or have thin arms or small hands. It was an absolute breeze to take off those four pesky bolts at the bottom when going from underneath.
97gstjosh said:So I don't remember if anyone posted this and I really don't want to scroll through 14 pages what wires are the 2gs using because don't you need longer wires to reach the coil pack?
I'm trying to find an EVO3 IM.. Anybody have any leads on where to get them? It's either one of these or save up for beyond redline's new SMIM. Along with the TB.
I would look around if someone sees this post and they have an extra im sure they will inform you. I would wait to get an EvoIII mani bec that redline one looks like $900 of garbage and I wouldnt believe those dyno numbers at all
Having mentioned the wheelspin and clutch slippage issues, it appears that I went from 306 h.p. previously to 334-345 h.p. at the crank in 1st gear. I had to get the tires warmed up pretty good to prevent the tire spinning but the clutch was consistently slipping past 7000 rpms and could be felt as a jerking sensation as it gained and lost bite, well past my power peak at any rate.
Logged a couple WOT pulls in 1st and 2nd gear with tires and clutch warmed up a bit to prevent slippage. This run was solid as the tires were gripping nice and good and the clutch was holding fine thanks to some engine heat transferring to the clutch.
Upon review of some of my fastest balls out race gas tuned logs, it appears that on pump gas with the MAF in place and pump gas fuel/timing I'm pulling as much power in 2nd gear as I did on race gas, speed density/MAF removed, higher ignition timing, lean A/Fs, and 30*F colder temps. Right around 375 h.p. in 2nd gear. Usually that number in 2nd gear nets about 390-400 h.p. in 3rd gear based on my previous DSMLink logs.
Over the next week or two I'll log a run with my race gas tune and speed density setup in place and finally a run with the temps 30*F colder so I can do an exact direct comparison of my fastest logs. I'd expect about 400 h.p. crank in 2nd gear.
On another note, man the throttle response is nice now. I don't know if its the combination of EVOIII ported intake manifold, bigger throttlebody, or phenolic spacers but getting off the line used to be a bit of a chore before. Now it feels just like my STi with its big torquey 2.5 Liter motor.
The removal of the stock 2g intake manifold was nothing short of a HUGE pain in the ass. With the EVOIII intake manifold in place and the EGR and various other trivial stuff removed I could pull this manifold in 15 minutes if I had to swap a gasket or something routine like that. Every manifold bolt is easily accessible from the drivers side thanks to the shorter runners. This is a huge convenience mod.
I'm just glad its going to a good guy. The install went well and the car woke up a bit more. Shes definitely coming together. How is everyone else in this thread? Anthony? Derek? Daren?
) I'll probably up my cam size abit as fwd emissions testing was holding me back (which will no longer be an issue). I also don't need to worry about fabing up a custom EGR setup anymore, as it won't be needed. I was planning on swapping to FP2X's (currently running FP1X's for those who don't know) to help out on the top end, but looks like their no longer available from FP. So not sure what I'll end up going with but it will be interesting to see if I continue to see airflow gains all the way to my 7500 redline with the new cams, as I'm think the 1X's being a midrange cam are the current limiting factor. Even with the 1X's wasn't seeing airflow level off till 7200rpm.I think this is my next mod,now I just have to find one at a fair price.
