Knocking when I don't ease into throddle slowly
turborebel
135
Nov 26, 2006
fredericksburg, Texas
Can someone help with this knocking problem that only occurs when I go too full thoddle very quickly. If I ease into the throddle slowly, I can have full boost without any knock. Has anyone else had this type of problem before?
Thanks,
Brent W.
Thanks, that might be some of it but I also have too run 10:1 AFR most of the time when past 10-15 psi of boost to control knock. I'm also running 100 octane Av gas, so it seems like knock should be low no matter what I do. This however is not always the case.
I would sell your programmed chip and get dsmlink. Then you can use the timing sliders to take out a degree or 2 in certian places in your timing map. Problem is the 1g ecu already has really aggressive timing maps and since your running 9:1 compression over the stock ratio your problems are amplified. Stopping knock by riching up the mixture has limits.
I have a less aggressive timing chip that Jeff gave me along with the more aggressive one that I'm currently running. It's just that I really liked the low end responce this chip has. I will give the other chip a try it to see if it helps.
Thanks,
Brent W.
  • For sale 4G63 COP Setup ( JMFab Plate & 300m Coils )
    COP Setup $185 + shipping & paypal fees* JMFab Plate & 300m Coils * 91-99 connectorYou must...
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • For sale 2g OEM 2G Headlight Set
    OEM 2G Headlight Set $90 + shipping & paypal fees* lenses present very well * all mounting...
  • Wanted Looking for A/C parts to reinstall.
    Looking for any/all components to 97 gsx air con system.
    • Schinjon
  • For sale 1g 1990 Turbo Manual Engine Harness
    1990 Turbo Manual Engine Harness $165 + shipping & paypal fees* all connectors are intact *...
