Knocking sound....
CarTrader29
228
Nov 19, 2004
Brooklyn, New York
Ok this just recently started to happen. I had this often before when I would hit bumps I think the exhaust pipe was hitting the differential. Went under the car and started shaking the pipe and I was right. Now I recently bent it away from the car but I still hear it. I know its still the exhaust pipe hitting it but some other spot. The weird thing is I just swaped rims and now it almost sounds like the driveshaft is hitting something. The faster I go the faster it knocks. If I hit a bump it goes away and comes back later on. Anyone have any idea what it might be?
Man, that can be anything. You're best bet is to jack it up and take a look. If anything looks too close, it probably is. Look for scratches or scuffs. Or support the whole car with jackstands and put it in gear and drive it in the air. Have someone look underneath while you're doing that.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
