Knock while idling
jd21
69
May 18, 2010
new tripoli, Pennsylvania
Im getting knock at idle 2.8 deg its not much but i cant figure out why i have not been able to do a pull yet i am waiting on a wideband. The sensor is brand new oem, should i just pull timing when it hits knock at 4500 rpms the knock goes away at 4700 rpms
link v3 lite i still need a wideband
also its not every time sometimes it wont knock at all
i will change my profile in a few mins thanks for the help. Im still new to link i just got it how do i post the log i have it saved to my desktop
just pulled another log here it is
ok thank you i just got link ive watched all the videos from ecmlink.com just a little bit conusing i never really tuned before. Would the front o2 be bad reading that low of voltage? Why would the knock sensor read bad when i just replaced it with an oem one, it was torqued to 17lbs
Knock sensor shouldn't even show up until the set parameters are met. IE./ 2200 rpm and throttle position > 35%
