Mahreeoh17
5+ Year Contributor
- 272
- 267
- Jul 12, 2020
California
Okay so I'm going back and forth between the old 99' 7 bolt motor and the '91 6 bolt motor and getting myself confused.
I'm going to use the 2G head with 99 CAS and 6 bolt block. Do I need the Kiggly crank sensor adapter if running this combo? Or just using everything that came with the 2G motor (OEM CAS and Crank sensors?) ECU will be 99 black box.
Thanks guys.
Thanks guys.
