2G Coolant temp sensor
Use your 2G sensor. With the the exception of the CAS (if using a 1G head), all sensors used should be 2G so that the signals are compatible with what the ECU is expecting to see.
okay i thought i tried to use a 2g coolant emp sensor but it didnt want to fit right but im going to double check. it fis right in the 1g spot?
