turbo coolant lines
naw9119
54
Mar 24, 2010
Athens, Alabama
OK guys here is my dilima. A buddy of mine is doing a 1g in a 2g swap. Here is the problem he is trying to run a 2g coolant pipe and turbo setup on a 1g block, so the front coolant line that is supposed to be fed off the block has nothing to hook up to. Is there another line somewhere we can tap into to supply the coolant?
and T-stat housing
It sounds like he doesn't have a problem with that side of the turbo cooling system. Only the side with the water pipe. You wouldn't wwant to run the coolant feed and reutrn both from the T-stat houing if that's what you are suggesting.
If he REALLY needs to run 2G water pipe you can always weld an AN fitting bung onto the pipe anywhere you want, and use an AN line and fittings to connect to the turbo.
The bottom of the radiator would also be a good source to do this if it is an aluminum radiator.
