Keydriver and 850cc injectors??
Bmxr152
579
May 27, 2006
Gardnerville, Nevada
How will my car run with 850cc injectors and a keydriver setup for the 850cc injectors? Will it run good even though the injecotrs are so big? I have... GM MAFT, EVo3 turbo, Wiseco 8.3.1 pistons, XS power FMIC, Ported Exhaust manifold, Walboro 255 fuel pump, full 2.5 inch exhaust, Data logger, boost controller, boost guage/.
The ECU is set to compensate for that size of injector. You can still fine tune with a SAFC. You can also specify your idle when getting your chip. You should talk to Andymoraits on these forums he can help you immensly.
-Adam
well its a used chip deal. IM getting a keydriver chip and 850cc injectors for $300. The kedriver specs are..
8500 rev limit
reset octane
no fuel cut
knock gauge
awd launch (4500-5500)
nlts (6k)
ac cutout
850rpm idle
850cc injector compensation
stock1g mas (I ran maft)
high speed closed loop
Everything looks in order there. There shouldn't be a problem running rich.
-Adam
hey, howd that setup end up running for you man? im going to be running almost the same soon..:hmm:
As long as the chip is properly compensated for the injectors, you can fine tune it with whichever piggypack you are using(safc,maft,etc).
A wideband is highly recommended and makes the tuning very easy in conjunction with a logger
those are pretty big injectors to still try and compensate with an SAFC. His staged chip is going to be a bigger asset than will the AFC.
Also, the 4500 launch is usually set for FWD cars. 5500 is the standard for AWD. I like the fact that it is adjustable for what the driver likes. I think 4500 is a really nice launch.
