ryboj
- 37
- 0
- Mar 14, 2005
San Diego,
California
New newbie here
This past Friday, I just scored a clean and unmolested 96 TSi FWD. I finally let my secondary car go, a 5.0 (once blown) after owning it almost 10 years, for some new satisfaction, a Turbo Talon.
And yes, its a 5spd, original CA car, 30yr old girl owned it before, and serviced it regularly. So no teenage abuse here. Not one oil leak anywhere, turbo still spools nicely, even if its a T25.
Im somewhat familiar with the mods of these cars from the past and what Ive read in all the tech articles and FAQs, but will need a little assistance with mine, as to where to go for best possible customer satisfaction and fair pricing ..
My bro owned a 92 AWD Talon before getting stolen a few years back, with a massive FMIC, 16g, fuel controller, boost controller, ECU mod, 2.5 exhaust turbo back, 2g ported mani, 550 injects, MA hack, all gauges, I believe 1g BOV not vented, etc etc at about 18-20psi. The car simply ripped and was enjoyable to drive.
Anyhow, I will be starting to purchase parts in the coming weeks. For now, just going over the basics, routine maintenance to make sure everything is in proper working order .
Going to be looking at checking/replacing the below first before mods:
1: Double checking the Timing belt/Balance shaft belt
2: Fuel filter
3: It has some new car quest wires, these need to come off
4: Replace plugs
5: Any hoses
6: Change over to Amsoil 10-30
7: Amsoil in tranny too
8: Check brake wear
9: Flush coolant
10: Etc etc 02s, knock, will wait
Then, I plan on following the FAQs for the most part and get this junk ordered up in the coming weeks .
1: Larger in-tank Walbro fuel pump (not sure if Ill do the rewire? or not)
2: Likely a 1G BOV, or the equivalent (not vented to atoms)
3: Intake pipe and filter (dont know which one though yet) dont want any hacking, want bolt on
4: Boost/Inlet temp gauge
5: Boost controller, havent decided which one yet, or elec or manual, need to read more
6: Turbo timer
Then, looking into a turbo back exhaust in the coming months. Im sure there are a gazillion options, so I will do plenty of research here. Prefer to do SS, straight through muffler design, no ricer tip, no serious exhaust drone or note, has to have cat since Im in CA, and does not interfere with other stock parts. Dont know if Ill do 2.5 or 3 ..
After the exhaust mods, I will look into a FMIC, but I may try and postpone this if possible. But if I need a FMIC before the turbo upgrade, I will have to do it. Not sure if my side mount can handle a bigger turbo or not. Need to read some more.
In the next 6-12 months, will do an injector upg, fuel controller, and turbo upgrade. From what Im reading, looks like the BigEvoIII 16g might do the trick for me, as the T-25 will run out of steam quickly. My goal is to be at 300-325whp, reliably, safe boost levels, and remain completely functional and streetable as a daily driver.
Let me know guys if Im on the right track ..
And just to confirm, I can only take my completely stock 2g setup to 15 or so psi safely on the T25, with an aftermarket BOV installed, right?
Thanks, Ryan
2: Fuel filter
4: Replace plugs
5: Any hoses
8: Check brake wear
9: Flush coolant
6: Turbo timer
Thanks, Ryan
This is NOT as common as it sounds and i just wanted to make sure you were aware of it. Lot's of people freak out and at the slightest problem, and they assume it's cw. Anyways, you will probably want to change you SMIC to a FMIC becuase with around 300+ hp, I'm thinkin the SMIC will become heatsoaked. Also, before you start any major mods, be sure to install a boost guage. The stock guage is not accurate at all so it's nice to know how much pressure you're pushin in real numbers.
The N1 from what I read has a deeper tone. Is it annoying by any means? Are the other Apexi setups more dinero, or the same price? Ive seen some, but they are costly. The N1 seems to be the most popular, or is it trendy?
