90AWDTalon
- 877
- 3
- Jan 5, 2003
Everett,
Washington
I just got my pocketlogger today. My current setup is GM MAF and translator, ported 16G@15psi, ported EVO III exhaust mani, 3" cat, 3" cat-back exhaust, and walbro 255 low pressure.
I did a 1st, 2nd, and 3rd gear log. There used to be a sight that on how to tune, but it seems to be down now, so I'm going to ask you guys for some help. http://www.hywell.org/plhelp/index.html
I looked at alot of the logs posted on these forums and it seems like I'm running pretty lean, which probably accounts for the knock I'm getting. So I guess what I'm asking is, are these two assumptions right? What range do I want the o2 to be in. That how-to had various levels of knock and what was acceptible, what was good, and what was way too much, can you guys fill me in on this. Any other input would be great. Also as I went up in gears the knock went up, but also the 02 went up. I had much more knock and was running richer than I was in second, and second was the same way compared to first. What does this mean, or is it normal. Another thing. The car was having trouble at the top of third, I was getting mid 20's to low 30's knock. Was I feeling the timing being pulled? It was being pulled in other area's but I couldn't feel it. Also in the logger I had it set to inj D\C which was around 95%, how do I convert from pulse width to duty cycle?
I havn't rewired my fuel pump yet, I'll do this tomarrow after work. It looks like I might need to turn the boost down a little, I'll do the rewire first and see what happens. If it doesn't help I'll turn the boost down.
Here's the log both as an attachment and pasted, I don't know what is prefered. Pasted looks kind of hard to read, but that is what most people do. http://home.earthlink.net/~del_sol/_uimages/3 gears.csv
Time RPM Knock Timing O2 Inj P/W TPS
01:00.6 3656 0 31 0.08 5.641 33
01:00.8 3719 0 30 0.71 8.462 100
01:00.9 4000 0 27 0.84 10 100
01:01.1 4156 0 25 0.84 12.308 100
01:01.2 4406 0 21 0.84 15.641 100
01:01.3 4844 0 18 0.84 17.949 100
01:01.4 5188 0 20 0.84 18.718 100
01:01.5 5438 7 18 0.84 18.718 100
01:01.6 5656 7 19 0.84 18.718 100
01:01.8 6031 13 17 0.84 18.462 100
01:01.9 6312 12 17 0.84 17.179 100
01:02.0 6406 12 15 0.84 16.923 100
01:02.1 6812 12 12 0.84 16.667 100
01:02.2 6969 12 12 0.84 15.897 100
01:02.3 7094 13 12 0.84 15.385 100
01:02.4 7312 13 12 0.84 15.128 47
01:02.5 7375 12 14 0.84 3.59 11
01:02.6 6750 9 41 0.63 2.308 11
01:02.8 6562 0 45 0.61 1.282 11
01:02.9 5938 0 45 0.59 1.282 100
01:03.1 5625 0 34 0.1 8.205 100
01:03.2 4531 0 26 0.82 11.795 100
01:03.4 4219 0 23 0.88 13.333 100
01:03.5 4281 0 20 0.86 15.897 100
01:03.6 4531 0 19 0.86 17.692 100
01:03.8 4562 5 17 0.86 17.692 100
01:03.9 4844 11 15 0.86 17.949 100
01:04.0 4938 11 14 0.86 18.462 100
01:04.2 5000 11 14 0.86 18.462 100
01:04.3 5031 10 14 0.86 18.462 100
01:04.4 5219 10 15 0.86 18.462 100
01:04.5 5312 10 16 0.86 18.462 100
01:04.7 5312 12 16 0.86 18.718 100
01:04.8 5594 12 17 0.86 18.718 100
01:04.9 5750 11 16 0.86 18.462 100
01:05.0 5844 15 16 0.86 18.462 100
01:05.1 5781 15 16 0.86 18.462 100
01:05.2 6000 15 16 0.86 18.462 100
01:05.3 5938 15 16 0.86 18.462 100
01:05.4 6031 15 16 0.86 18.462 100
01:05.5 6062 18 15 0.86 17.949 100
01:05.6 6156 18 15 0.86 17.436 100
01:05.7 6219 18 15 0.86 17.949 100
01:05.8 6500 18 14 0.86 17.436 100
01:05.9 6406 18 12 0.86 17.179 100
01:06.0 6531 18 12 0.86 16.667 100
01:06.1 6688 17 12 0.86 16.923 100
01:06.2 6719 17 12 0.86 16.923 100
01:06.3 6750 18 10 0.86 16.667 100
01:06.4 6719 18 10 0.86 16.667 100
01:06.5 6969 18 9 0.86 16.154 100
01:06.6 6875 18 11 0.86 16.41 100
01:06.7 7125 17 10 0.86 15.641 100
01:06.8 7000 17 11 0.86 15.641 100
01:07.0 7188 17 11 0.88 15.897 76
01:07.1 7156 17 11 0.88 12.051 15
01:07.2 6969 17 29 0.69 3.077 11
01:07.4 6438 6 44 0.65 1.538 37
01:07.5 5969 0 45 0.33 8.205 100
01:07.6 5531 19 21 0.88 12.821 100
01:07.8 4656 19 14 0.9 15.641 100
01:07.9 4750 19 11 0.9 18.205 100
01:08.0 5000 19 11 0.9 18.718 100
01:08.2 4906 18 11 0.9 18.462 100
01:08.3 4938 18 11 0.9 18.462 100
01:08.4 4969 18 11 0.88 18.205 100
01:08.6 4969 18 12 0.88 18.462 100
01:08.7 5031 18 12 0.9 18.205 100
01:08.8 5250 17 12 0.9 18.462 100
01:09.0 5125 17 14 0.9 18.205 100
01:09.1 5250 17 13 0.88 18.205 100
01:09.2 5219 17 14 0.88 18.205 100
01:09.3 5344 16 14 0.9 18.462 100
01:09.5 5438 16 14 0.9 18.462 100
01:09.6 5312 16 14 0.88 18.205 100
01:09.7 5406 16 15 0.88 18.462 100
01:09.8 5438 16 15 0.9 18.205 100
01:09.9 5469 15 16 0.9 18.205 100
01:10.1 5531 16 15 0.88 18.205 100
01:10.2 5625 16 15 0.9 17.949 100
01:10.3 5656 16 15 0.9 17.949 100
01:10.4 5688 16 15 0.9 17.949 100
01:10.6 5750 15 16 0.88 17.949 100
01:10.7 5844 15 16 0.88 18.205 100
01:10.8 5844 15 16 0.9 18.205 100
01:10.9 5719 15 16 0.88 18.205 100
01:11.0 5812 15 16 0.9 18.462 100
01:11.1 5750 20 15 0.9 18.205 100
01:11.2 5875 19 15 0.9 18.205 100
01:11.3 5906 19 15 0.88 18.205 100
01:11.4 6000 19 15 0.88 18.462 100
01:11.5 6062 19 15 0.9 18.205 100
01:11.6 5906 19 15 0.88 17.949 100
01:11.7 5969 23 14 0.9 18.205 100
01:11.8 6156 22 13 0.88 18.205 100
01:11.9 6125 22 13 0.88 18.205 100
01:12.0 6125 23 13 0.88 18.205 100
01:12.1 6125 23 14 0.88 18.205 100
01:12.2 6125 23 14 0.88 17.692 100
01:12.3 6094 22 13 0.88 18.205 100
01:12.4 6219 22 12 0.88 17.949 100
01:12.5 6281 22 12 0.88 17.949 100
01:12.6 6219 22 13 0.88 17.949 100
01:12.7 6344 22 12 0.9 17.692 100
01:12.8 6500 22 12 0.88 17.949 100
01:12.9 6281 21 11 0.88 17.949 100
01:13.0 6438 21 11 0.88 17.692 100
01:13.1 6406 21 11 0.88 17.179 100
01:13.2 6406 21 11 0.88 17.179 100
01:13.3 6438 21 12 0.88 17.436 100
01:13.4 6562 21 11 0.88 17.436 100
01:13.5 6500 20 11 0.88 16.923 100
01:13.6 6594 20 12 0.88 17.179 100
01:13.7 6688 21 10 0.88 17.692 100
01:13.8 6469 21 11 0.88 17.179 100
01:13.9 6500 21 8 0.88 16.667 100
01:14.0 6656 26 9 0.88 16.667 100
01:14.1 6594 25 10 0.88 16.923 100
01:14.2 6719 25 9 0.88 16.667 100
01:14.3 6812 25 8 0.88 16.923 100
01:14.4 6688 32 7 0.88 16.41 100
01:14.5 6906 32 5 0.88 16.923 100
01:14.6 6781 32 5 0.88 16.41 100
01:14.7 6844 31 7 0.88 16.41 100
01:14.8 6906 31 6 0.88 16.667 100
01:15.0 6844 31 7 0.88 16.154 100
01:15.1 6844 32 4 0.88 16.667 100
