j3rkoff
- 47
- 0
- Jul 29, 2003
ArizonaUS
OK, I'm about to go out and log my first run... Due to the BS gas shortage in AZ, I'm going to wait an hour for gas first . Thanks to the people in this forum, I finally got a logger...
Now i've searched here and have read the stuff that came w/ pocketlogger, but i want to ask anyways what exactly I should log for my very first run... LTFT, timing, o2, etc... What should I be shooting for (esp. timing-wise)?
Also, If timing dips, I raise fuel, correct? And if LTFT is in the negatives, I lean it out on that point w/ the AFC? And since there isn't an exact measurement of knock on the 2g's, I have to look at where the timing dips and EGT to make an educated guess?
a couple more questions... I have a 190 lph fuel pump, and 720 injectors. I have a crap hrc s20g turbo (might as well tune it since i'm stuck with it until later in the year), is that enough fuel system mods to run it over 20 psi? Also getting an SX FPR soon. I'll get a fuel pump if you guys think it's necessary, but for right now should I be OK?
How high can i run the boost in this turbo? People say it's got too small a compressor wheel, and too big of an exhaust side, so it takes forever to spool up, which is true. Just wondering how high I can turn it up until either the turbo isn't efficient anymore or is too dangerous.
I can't wait to get started tuning . Thanks, and sorry for all the questions.
