bastarddsm
- 5,761
- 1,690
- Aug 26, 2003
Mendota,
Illinois
So I recently had a standard wiseco wrist pin fail. I'm building a new motor with JE's, and I'm kind of spooked about the pins.
The JE pins are thinner wall than the old wiseco's. Has anyone had problems with JE wrist pins? My car made 650whp with a well worn motor, so it will probably be making more with a new motor and more compression. Is there and upgrade for JE wrist pins? They are shorter than the wiseco ones so I don't think 1400hd pins would work.
I haven't called JE on the matter yet, but planning on it.
I'm not buying a set of 1400hd's either, or any other piston for that matter.
Also first hand info only. If you post about your friend's car, I will drive to you house and burn it down.
), 9310 is a much superior material for wrist pins over 5115. The fatigue resistance is huge compared to 5115
