Jdm engine identification help
pimpin81
524
Dec 14, 2007
bellingham, Washington
ok i bought a 7 bolt red top engine i need to know everything about this engine so i can swap the right stuff over.
What I Know About The Engine :
7 bolt jdm redtop------- mitsubishi up top dohc 16v on bottom of valve cover
Automatic
2 black injectors 2 blue ones completly different style injector plugs/ injector harness more 1g 6 bolt stylish
different smaller shorter intake manifold with no throttle bodie elbow
different water jacket and powersteering brackets are different then the 95 gsx 7 bolt i have
different style ignition coil
small turbo with completley different outlet setup and waste gate location
mabey some other things i havnt noticed..
motormount is the same.
its it an rvr motor, a galant motor an evo motor ect ect.....
what i want to know is what this engine came out of this and should I swap the cams from my 5 speed usdm 95 gsx ,throttle bodie ect.....
any other helfull hints i pulled the old motor out today so prep work is underway, i play on putting my usdm exhaust manifold turbo ect on, usdm intakemanifold and fuel rail/injectors, change the waterjackets over, and the power steering and alternator brackets, coil packs to the jdm engine
does anyone have any information on this? if i put my 5speed usdm cams in the jdm engine that was previously automatic what kind of perfomance gains if any will i get ?
Automatic
pictures will describe more , btw the red top are all galant vr4's 6bolt
You got an automatic turbo motor there with a small 13B turbo (180hp stock) and the two bluetops should be black since the auto turbo used blacktop 390cc injectors. bluetops are 450cc injectors made for the manual tranny. I'd find a 14B to match the 450cc injectors to get more stock HP.
...or, just the redtop cover from a VR4 sitting on a 7bolt that the motor came from a mitz..for VR4 motors have diff motor mounts setups and incompatible with DSM's.
