1G J pipe option for 1g
AlexGsxCummins
395
38
May 31, 2014
Bremerton, Washington
Hello, I'm about to order a vrsf fmic and read alot about only the vrsf j pipe will work with the kit. When I went to order it there is not option for a j pipe.. what would i have for options at this point. Thanks!
Do you have the stock jpipe from the 16G? If so, you can mod it to face towards the front of the car then run a 90 degree 1.75" silicone reductor to whatever your piping diameter would be. Check my build if you want to see how it ends up looking. However depending on your turbo and radiator fan setup, you may not have room for this.
I'm thinking I'll just order the punishment racing kit my end goal is 450-500 probably on a hx35, I think that kit from reading around should manage that goal. For now it's just a big16g
https://www.cxracing.com/KIT-1G-IC0044-350-BOV009
This is VERY close to the VRSF kit.
J-pipe doesn't have a boost nipple and the BOV flange isn't interchangeable like VRSF but the core looks like my 3 VRSF cores.
Just FYI.
It sells for $331 I think I saw.
Pops
