Its time for a timing belt, water/oil pump change.
JeanDSM
405
Jun 23, 2004
Yabucoa, Puerto, Puerto Rico
This is the first time that i am going to change this stuff since i got the car. Previous owner (my cousin) did it 50K miles ago. I want it all OEM Mitsubishi: timing belt, tensioner pulley, idler pulley and tensioner, balance shaft belt and balance belt tensioner pulley. Should i get water pump and oil pump Mitsubishi or can i get it from another aftermarket company like Top Line in Slowboy Racing. About timing belt is mitsu enough or is it a good buy a power enterprise belt or a GReddy belt?
What else do i need to buy for a 2g GST total tune up?
When doing a timing belt job on your dsm, its always recomended to use oem belts and parts. If you are going to replace the oil/water pump i'm sure one of the sponsors on the sight will have what you need.
