nosdsm3
- 68
- 0
- Sep 11, 2008
Glens Falls,
New York
I bought my 2g new put 50,000 miles on in the first four year I owned it as soon as the warranty was up it died. I have had it since 1999 and still love it.
One less thing to worry about.did you unbolt the 80amp fuse that has like 1 bolt on each side???cause i was haveing the same exact problem and thats what it was the fuse is black so you wouldnt know its good unless you look realy close
Did you have the alternator checked while the car was running, or out of the car being tested on a machine?
My alternator was reading 9.5v on the car at idle, but yet it still passed the auto parts store test. Basically it was doing fine when it wasn't under load, but it couldn't keep up when it was under load.
Replace the alternator, if its out anyways, might as well throw a new one in it, so you don't have to worry about it. Most have a lifetime warranty anyways, so one you replace it, keep your reciept.. you won't have to buy it ever againOne less thing to worry about.
Okay guys, I am stumped and getting angry again.
I replaced the fusible link/alternator choke....even though the old one tested out just fine. I checked the alternator contact points and connections and they were good. I also checked the fuses again. My f***** alarm wouldn't shut off even after I disconnected the battery terminal. So I removed the entire alarm "box". I disconnected the amp battery too. NO CHANGE IN ANYTHING!!! Actually that's a lie, now it wont even start even thought the battery is charged. So, it's obviously worse now. I give up....what the f*** else can it be?
Still 11.1 v when the ignition is on but 12.4 when it's off. Since none of the fuses are blown I can't imagine that there is a short anywhere but at this point I have no idea. HELP!!!
One Equals Two said:Then, 2 days later, my battery looks like it's going to take a crap, or the alternator.
I had the same headache for a while, same burn on hand from battery terminal. Not starting, leaving me stranded.
The problem was the positive BATTERY TERMINAL! I cleaned it all I could, with a knife, baking soda wire brush, even a wiz wheel, it would still short out. Finally I replaced both terminals and don't have anymore problems.
Is the only problem the low voltage? Does the car still drive? Why did you have to limp home when the car should have a hand jack and tools to tighten your lugs?
Just to clear some things up, can you describe what the problem is? You said the voltage is 11v when the ignition is on and 12v when it's off - this hardly seems like a problem. The car won't start now but before you removed the alarm and amp battery it would start? I think you'll get some more help after people decide to quit telling you to keep it and when they understand what is actually going on with the car...I still don't understand the initial problem:
hard to turn over? dim lights? smoke coming from the rear-view mirror? what's going on?
So, you have power in the car but when you try to start it it shuts off?One Equals Two said:All the lights are fine (bright) all of the instruments are on and "strong" like the radiator fan and blower motor.
I'd work on getting the car started first though.
Why do these aftermarket pieces of s*** behave like this?I have power to the inside, but not the starter.
When I disconnected the alarm, the starter also lost power.
