DevilsAWD
- 54
- 0
- Apr 18, 2009
Thermopolis,
Wyoming
Hi Everyone,
I recently picked up a 1990 Talon TSI about 6 hours away from my home. the car was running strong so i decieded to drive it back home. (new head, new timing belt, new alternator/belts. new radiator and hoses)
During the drive I was able to pinpoint some key problems with the car. First. the turbo leaks a little oil. ( I suspected this on the "test drive")
one thing I didn't expect was what appears to be a fuel issue. the car was accelerating/boosting just fine for the first 200 miles. then everytime I would put the pedal down the motor wouldn't rev much past 3000 RPM. the car would start "bucking" some trouble lights came on My battery light and one I don't recognize... looks kind of like
O
searched for it and couldn't find anything. Anyway's limped it home. Oil pressure, Temp and all other noticable things stayed within very good operating limits.
I pulled the car into the garage and turned it off.
The next day I went back out "fiddle" with the car. replaced the spark plugs. which were not fouled... the instead had a "white" tinge to them. it looked as though they were being starved of fuel.
Replaced the fuel filter, which was severly clogged (doubt it's been done in twenty years. I then tried to start the car. it turned and turned and turned. Finally it started, reved to 2k RPM. then I touched the gas, the car bogged down and died.
I assume fuel pump. however after disconnecting the fuel line at the filter and turning over I am indeed getting some pretty decent fuel flow.
I am building a "boost leak tester" tonight so i can rule out a leak.
so I'm at a loss. I'm getting fuel, but everything appears as though I'm not getting fuel.
perhaps an injector problem?
any help or suggestions on where to look would be awesome!
Thanks,
-Devs
O
Thanks,
-Devs
the temp gauge was pegged above "hot" and the car hasn't run for 3 days... oh gee can anyone say coolent temp sensor?
